Passenger Side Exhaust
Discussion in 'Technical' started by Maverick_Ian90, Apr 22, 2024.
  1. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    Last week I took some time off work to get things done around the garage. I bought Hedman shorty headers (I'm on a budget) and noticed the extension the bolts to the collector goes right into the passenger side floor board. I assume the easiest option is to cut the extension down, but was wondering if there were any other solutions used.
    FYI for anyone buying them: The drivers side extension hits the pitman arm. Another issue for another day.
  2. mojo
    I have same headers on my 73 and have no issues with bolt hitting on pass side, driver side hits pitman arm.
  3. Maverick_Ian90
    Northeast
    How did you get around the pitman arm issue?
  4. mojo
    I didn't; I've heard others use a BFH modifying collector to get less interference, but I don't think you can dent it enough to get full clearance of the pitman arm w/o negatively restricting exhaust flow. I've just adjusted to less turn radius in that direction and really when i installed them didn't want damage the nice silver coating. Also, I didn't use collectors that came w/ headers, ordered smaller ones that's what's on the car now. Others may chime in w/ what they have done in this situation. Been driving like this over 5 years, use too it now.
    Lastly, I would think Hedman making these long enough to have made mods to fix this.
    Maverick_Ian90 likes this.
  5. maverick600
    maverick600 Member
    San Angelo, Texas
    I have the same headers and had the same issue. On the pass side, the exhaust guy cut the extension part off to make it a flange connection. On the drivers side, we used a 45° flange to turn it towards the oil pan and it clears the pitman arm. My car does not have power steering though.
  6. Craig Selvey
    Modified driver side collector like this:
    Made passenger pipe like this:
    mojo and Maverick_Ian90 like this.
  7. mojo
    Strange, I didn't have any problem on pass side, slide easily from under the car after unbolting idler from frame. I almost believe it would have gone in from top if not for heater and AC hoses. Maybe I look into what mods you n Craig made to solve this issue. Muffler shop I had install exhaust system does custom work, confident they can get it done.
