Perfect Timing for Distributor
Discussion in 'Technical' started by 71COMETGUY, Aug 8, 2016.
Tags:
  1. 71COMETGUY
    71COMETGUY Member
    Los angeles
    71 comet
    Car is running a bit off beat think its the timing. What is a good timing mark for a inline 6 250. Just put in petronix coil and points and new cap, rotor and spark plugs. Thanks
  2. 71gold
    all engines are different, that's why they give you a starting point (degree).
    check for vac. leak first. then what I do is with a vac. gauge set the timing to the highest vac. reading by turning the dist. once to the highest reading on the gauge I back the dist. reading off two degrees of timing...JMO
    greasemonkey and rthomas771 like this.
  3. bmcdaniel
    bmcdaniel Senile Member
    The book says 6* BTDC for your engine but I would probably give it 10 or 12 degrees advance.
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Have you ever checked your total timing after doing that? Just curious what it ends up being.
  5. 71gold
    nope...
  6. bmcdaniel
    One way I've used on non-stock engines to find how much initial advance they like is to warm up the engine, advance 2*, shut down and let the engine heat soak for a minute and then try and start it. If it starts ok bump up the timing another 2*, shut down, heat soak, restart. Keep doing that until the engine drags the starter or coughs through the carb when starting and then back off 2*. The only time that didn't work was when I was running a 300* duration cam, I got to 21* advance and stopped.
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    If you're running Duraspark ignition, that method won't work. It has a cranking retard for easier starting.
  8. bmcdaniel
    I've never had a Duraspark and it doesn't look like the OP does either. IIRC, you just need to disconnect the white wire from the Duraspark and put 12v on the coil to defeat the start retard feature.
  9. krelboyne
    krelboyne Remember
    Salem, Oregon
    I have read somewhere on the Ford forums, that with the Pertronix ignitor and coil you should widen the gap on the spark plugs to take advantage of the better spark for combustion.
  10. WA8DDN
    WA8DDN Member
    Malvern, Ohio
    '74 Grabber, 302,C4,3:80 to 1 Traction lock. 1973 V8 car,LDO
    Back in the 50's and 60's we would advance the timing a couple of degrees at a time until it would ping a couple or three times when we really lugged the engine down.
  11. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Just an fyi. Unless you have checked the harmonic balancer your timing probably won't be exact when set with a light.
  12. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    I've always gone by the butt dyno, never used a light. Always advanced until it feels weaker or starts to ping, then back off a little(to most power point, or just before ping), and made sure it'd restart while hot. Every engines different 1 engine might like 32° another might like 38°, just gotta try stuff see what works best. You can also read the spark plug ground strap.
  13. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The problem with that method is that detonation can be happening even if you can't hear it.
    mav man likes this.
  14. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Done it that way for years, never had an issue. That's why you really should read plugs.
  15. mav man
    mav man Member
    wi
    70mav
    I'll stick to my timing light. I would do it by ear if away from the shop,but best to go with lightthen you can verify your advance and everything is working right
