please help
Discussion in 'General Maverick/Comet' started by steelsub, May 27, 2008.
  1. steelsub
    steelsub Member
    pennsylvania
    1973 maverick
    Hi i found two comets one is a 71 and one is a 74 the hoods grills and bumbers dont look like thay would fit my 73 maverick but what else would fit both comets have 200 in them. thanks
  2. Dave B
    Everything else would fit, if there both 2 doors.
  3. steelsub
    steelsub Member
    pennsylvania
    1973 maverick
    both are two door one is a 4 bolt and one is a 5 bolt rim
  4. CaptainComet
    All the 5 bolt suspension from the 74 ought to go in there with no worries. Is it disc brakes on the front? ... that would be an excellent improvement if your 73 is an all drum car. If it is power brakes, then that hardware and shock tower brace is different, but can swap over.
    The doors changed in 73 ... extra bracing and different interior trim and handle location, so using the earlier doors is complicated by that.
    Back seats and interior surrounds changed in 72.
    Rear bumper on the 71 and 73 ought to be the same.
    Other than that ... most everything else ought to interchange.
