plugging firewall holes....
Discussion in 'Technical' started by mashori, Jun 22, 2012.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    What do you guys use to plug up the holes in the firewall? I have all sizes, Swiss cheese really. Is there some sealant I can use that will also plug up the spaces between wires that run through the holes as well?
  2. 71gold
    yes...(y)
  3. Bob Wiken
    Fayetteville, Arkansas
    Good answer Frank
  4. Bob Wiken
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
    POR Epoxy putty would fill holes. Around wires I would probably use black silicone
  6. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    I wouldnt put sillycone around wires coming through the firewall. Had an old jeep cherokee that someone did that too, and trust me it was a nightmare whenever something got changed with the electrical system. There is no just pulling one wire out of a hole there is pulling all the wires out feeding them out, cutting the silicone apart, seperating the wires and figureing out how to clean up the mess when you are trying too put it all back together.
    A better option is too make the holes nice and round if possible and put rubber body plugs in the holes that the wires/hoses go through.
    Something like these
    you can also get body plugs made specifically for running wires through too.
    Here is a 125 peice kit for you on ebay for less then $15.
    http://www.ebay.com/itm/125-Rubber-...Parts_Accessories&hash=item35bd7529b3&vxp=mtr
  7. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Just don't knock the container off the shelf or you'll be picking up grommets for the rest of your life. :mad::oops:
  8. DC12VOLT
    DC12VOLT Fuel Injected
    Everett, WA
    Cream 1971 Maverick
    I find those rubber grommets to be extremely valuable. When I want to run wires through I use one and cut a "+" shape in it :thumbs2:
  9. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    This is great guys. Thanks
  10. 71gold
    ...:thumbs2:...:yup:
