points
Discussion in 'Technical' started by rab1969, May 3, 2011.
  1. rab1969
    rab1969 Member
    north carolina
    Maverick
    Any one have an ideal why I keep burning points out in my 302? New points take about a month to burn up. I will install a new set in about a month they are burned up so bad that I will have to install new instead of just filing and resetting. Any thought on this?
  2. Acornridgeman
    Wisconsin
    Are you changing the condenser too? If not, that would be the problem. New condenser.
    :thumbs2:
  3. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Also, do you lube the cam?
    If engine is not running don`t leave ignition on.
    I`ve not done it except in school, the tension on points have spec`s andare to be checked.
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    How much voltage do you have running to the coil? Points only need about 6-8 volts, more than that will burn them up pretty fast. Your resistor wire may be bad. I have had the same set in my car for three years now, and haven't even had to re gap them.....
  5. rthomas771
    Wrong coil ohm
  6. tomboy
    tomboy Member
    you might also check the I wire on the starter selenoid and make sure its not stuck and sending 12 volts to the coil all the time, instead of just when cranking.
  7. rab1969
    rab1969 Member
    north carolina
    Maverick
    thank you every one for the advice I will check out the coil problem.
  8. darren
    Why dont you go to duraspark and get rid of the points???
  9. john T
    john T Member
    coalinga CA
    72 maverick grabber
    x2 get rid of the points i went with the accel unit on summit and bought a blaster 2 coil at the same time works great
  10. yokeracer
    yokeracer Member
    Cleve, Oh
    72 comet GT
    I second that, I did away with the points the other day, and got a MSD electronic module. Along with an Accel coil, works damn good now, maybe even better.
