pontiac 350
Discussion in 'Other Automotive Tech & Talk' started by johnson, Feb 26, 2012.
  1. johnson
    johnson Member
    fargo, ok
    69.5 maverick
    So the 455 got bought before I could get it. Back to trying to fix the 350. Not getting oil to the rockers. Pulled the oil pressure switch and put in a manual gauge. 50psi at the bottom end. Brings me to can,lifters, or a plug somewhere. Does anyone know of a higher oil port on the top end of the block?
  2. simple man
    simple man Member
    Bunnell,Florida
    The one I had ( 72 ) oiled through the lifters and up through hollow pushrods to the rockers. I'd see if your pushrods are clogged. Very unlikely I know, but I have seen stranger things happen! :)
  3. johnson
    johnson Member
    fargo, ok
    69.5 maverick
    I soaked them in diesel, ran a wire through them, and then blew them out. Once reinstalled. I still had nothing
  4. bmcdaniel
    I believe the top end gets oil from the #1 cam bearing and they sometimes have issues.
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
