Posi rear end for 75maverick
Discussion in 'Technical' started by Mercury-beast, Apr 5, 2010.
  1. Mercury-beast
    Mercury-beast Member
    cali
    1975 ford maverick in process of having a 89 roller
    anyone selling one or know what to get from another vehicle? i tryed search by and had no luck at all,
    or does anyone know a shop in cali that sells or makes them with my rear end at a good deal? thanks
    or a website either works
  2. baddad457
    The easiest way to a posi type rear is to by a unit new and have it installed in the rear you have now. Do a gear change too while you're at it, it will likely benefit from it. Stock posi (traction loc in a Ford) units are few and far between that were a direct bolt in deal with these cars.
  3. CaptainComet
    Mavs came with an 8" rear axle at best ... if yours has a drop-out center section, that is what you have there. These have always been tough to get a posi for. Early Mustangs got some, but they are rare ... Mustang IIs and Pinto/Bobcat wagons got some too, but they are really hard to find.
    Auburn makes a new unit that will go in an 8" for between $400-500 IIRC.
    Some guys will put a 9" axle under a Mav just because they are easier to find a posi on the cheap, but most are too wide to go in our cars and need narrowing ... that jacks the price up.
    An 8" will live a long time in a light car like ours until you really get over about 400 HP and keep hammering on it.
    8" or 9" ... you are probably looking at $1000 minimum to get a posi axle in a Mav.
  4. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I have an Auburn Limited slip on the shelf but shipping to Cali from Tenn, I don't know about. Maybe the same as ordering one from Summit.
  5. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    You may check wity Bryant at San Diego Gear and Axle he may be able to help.
    He is a member on this form and has a add on here.
  6. Mercury-beast
    cali
    alright cool thanks
  7. Bryant
    i can get you an auburn for around 475. i can install it also. if you get one some were else i can install your parts also. a quick warning, if the housing is bent then you will need to get it streightend or it will wear the posi out qickly. i find if the axles are hard to pull out then thats a good sign that its bent. where in cali do you live?
  8. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    Does Richmond still offer the Lock-Right and do they have one for the 8"? I bought one about 5 years ago from Jegs for my 71 F100 9" rear gear for less than $250. It is not as robust as a Detroit or Auburn but is is true positive traction when you feed the gas to it no matter if you are in a turn, in the sand or have one wheel jacked up in the air. I actually tried that as a guy on another forum said they wouldn't do that. I jacked up the left wheel while in the shop and it pulled the truck across the shop with only one tire on the ground. Doesn't matter which tire either. I have moved it from one gear to the other without worrying about the gear set up either which is nice.
    Cheap easy way to get a positive traction rear end.
    clint
