power loss.
Discussion in 'Technical' started by RudyD, Dec 24, 2005.
  1. RudyD
    RudyD Pretend Mechanic.
    Ft. Collins, Colorado
    1970 Maverick.
    Hey everyone, been awhile since I posted here. I still stop by time to time and read the archives. Anyhow, I've been having some problems with my 73 302 maverick lately. I'm guessing that the mixture is to rich but just thought I'd ask in case anyone has anything else to add to it.
    When I lay on the pedal pretty hard the engine will sputter at high RPM and make a sound like a quiet backfire coming from under the hood (most likely from the carb) and when I get on the interstate after a few miles or after gunning it down the onramp, the car will get to the point where it will cut out if I give it much gas at all, I can do enough to keep it at 75 but if I needed to accelerate quickly, it would cut out and I'd be screwed.
    This is a car that I originally intended to use as a parts car for my 70 maverick but have turned it into a daily driver while school continues to make me poorer and poorer. The engine is in poor shape, the rings are pretty much toast, it smokes at startup and when under heavy acceleration.
  2. sierra grabber
    sierra grabber Certifiable
    northern nevada
    when the car smokes under heavy accleration, is it white or dark? Have you tried running the carb off of your other mav?
  3. waynes fords
    waynes fords Member
    fayetteville,Georgia
    1973 grabber,2004 ford dually,2000 gulfstream motorhome,2003 ford expedition,66 mustang gt
    what kind of carb is it? check these things that come to mind...plugs for gap and cleaness,timing,adjust the carb, do you know how to use the lean drop method? put some Lucus products in you motor to help with the bad rings (not a fix) but might help for a short time,check for proper carb operation-sounds like something stuck or gummed up,if its high mileage it might just worn out!
  4. stmanser
    Davenport, Iowa
    i would suggest the following
    you are blowing smoke, sounds like the plugs might be fouled....
    also i would be looking at the points in the distributor the gap might be gone......
    maybe the vacuum advance (if so equipped) could be bad, not allowing advnacement of timing at RPMS.
    good luck
  5. RudyD
    1970 Maverick.
    It blows white smoke, the exhaust pipes are dark black due to accumlation of oil. The carb is a Edelbrock 4 barrel.
  6. waynes fords
    waynes fords Member
    you need a motor! sorry for that news but if it is high miles and all these problems then save yourself some money and price a long block and change everything over. Merry Christmas
  7. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    This white smoke...Does it have a bluish tint to it?
  8. Bluegrass
    Bluegrass Jr. mbr. not really,
    Easton, Pa
    73 Comet GT, EFI, C4, Posi
    You say your problem shows after heavy throttle use in several different senerios.
    The backfire is leanness.
    The fuel pump can't supply enough fuel and the carbs runs out of fuel.
    Change the fuel pump.
  9. RudyD
    1970 Maverick.
    The smoke doesn't have a blue tint to it, just white. I agree with the post about my motor being shot, think of this post as damage control, this car is only meant to be drivin till it dies, not much more. My 70 Maverick will be the one that eventually gets a new motor, my 73 (nicknamed Smokey) is a winter/parts car. As far as the fuel pump, that does make alot of sense, but here is my dumb question for the day, is there more than one? I know there is a sending unit in the gas tank but is there another one along the line somewhere? If there is more than one, which one do I need to replace? Thanks for any replies, and thanks for the ones I have received so far.
  10. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Sounds like a weak fuel pump to me. Fuel pump is located on the drivers side of the engine, in the front, towards the bottom,, you will know it when you follow the fuel line. Only 1 fuel pump installed from factory, unless somebody got creative, still probably the only fuel pump on the car.
    Dan
  11. Cleaver
    Cleaver Member
    MD
    Chel
    I'm thinking real simple first. With the air cleaner off - look at the squirter and work the linkage by hand. When you work the linkage the squirter should shoot 2 strong streams of fuel into the venturi. If it doesnt or is sputtery.......pull the accelerator pump diaphram. If this is a factory ford 2 barrel it should come off the front with 4 small screws. About 1 inch in diameter. If you are real careful you can pull these off without destroying them. More often the part of the gasket tears and you have to replace them. Pretty easy to do with carb on a bench - nearly impossible on the car.
    More important when the diaphram is off - look at the little rubber flapper valve. There could be dirt around the flapper valve that allows the fuel to go back into the bowl as opposed to running to the squirter. Pull the flapper back and inspect the fill hole from the bowl - it could be clogged. Run a thin wire (pull the paper off a bread tie) through the hole behind the flapper valve and also up through the squirter hole.
    Cleaver
  12. EFIMAV
    EFIMAV Member
    Davenport Iowa
    UHHH, lets go real simple and ask if the fuel filter has been changed lately!
  13. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    The engine is in poor shape, the rings are pretty much toast, it smokes at startup and when under heavy acceleration.[/QUOTE]
    does the car use water? white smoke indicates a blown head gasket. only at start up and under acceleration has me scratching my head though. if the smoke had a blue tint to it i would have to say valve guides.
