Progress (or lack there of)
Discussion in 'General Maverick/Comet' started by lngroller, Jun 30, 2005.
  1. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    Well here are some photos of where I am now. Cowl top drilled out and patched, (not rewelded back yet), Drums converted to disks on front, new shocks, cut 1 coil from coil springs, and just finished doing the PA performance Alt upgrade 95A. The heater core was shot so I have the dash out (mostly) and have a new heater core but I am trying to find an A/C evaporator before I put it all back up. Mine should be OK but new one could save me from pulling it all apart again. I have the White guage faces installed, and an interior swap to buckets (already here) and Black interior to come shortly. Next project today is rear brakes, I need to replace the brakes and wheel cylinders and I am hoping that is where my emegency brake cable is froze up. when that is done reweld the cowl then start body work and paint. Interior last.
  2. CometPrincess
    CometPrincess Member
    Port Charlotte, Florida
    1976 Comet 4dr, 1972 Comet 4dr, 1977 Maverick 2dr
    Looks like fun, good luck with it!
  3. just1993
    just1993 Mike
    Zionsville, PA
    70' & 71' 2 Door and 76 4 Door
    Are you doing all this work outside. Your braver than the average guy. Does look like your making great progress. Keep up the good work!!
    Mike
  4. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    Yup all outside. My 2.5 car garage is now an office/studio and my doors are only 5' wide. Maybe if I take the wheels off and turn it on it's side I can get it in there?
  5. Mercurycruizers
    Venetia, PA
    Looking good! Yes, you are braver than me, to be working outside....
  6. bmcdaniel
    Maybe if I take the wheels off and turn it on it's side...
    :D Take pictures of THAT!
    Your car is coming along great!
  7. Jamie Miles
    Alto, GA
    I've had a few
    Lookin' good! (y)
    Whats wrong with working outside?
  8. Mavaholic
    Looks good to me.
  9. 74merc
    74merc computer nerd
    1974 Comet
    Rain. Sun. Hail. Lightening... acts of God, that sorta thing... :D
    The cowl is a fun job, aint it?
  10. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    "The cowl is a fun job, aint it?" UH HUH, but not as bad as I anticipated.
    I figure if I turn the car on it's left side and push it in I can put it on it's right side to push it out and both sides should match right?
    PS. got both rear wheel cylinders in, Rear brakes, and installed the 95A PA Performance Alternator today. Tomorrow comes freeing the emergency brake cable.
  11. buckcreek
    buckcreek Member
    somerset, ky
    73 MAVERICK STANDARD 2dr 302 auto.
    I lost what are you doing to the front cowl?
  12. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    The inside/bottom was rusted out so I drilled out all the spot welds and removed the top. then fiberglassed the bottom. Just have to reweld the top back on now. I would have welded patches in but I still have a lot of wireing in the dash and didn't want to risk it.
  13. 74merc
    1974 Comet
    heh, you're lucky. I didn't have enough solid steel left to fiberglass it. Definately get some really good paint or POR15 or something on whats left of the steel cowl before you weld it back up. Mine looked solid in the center of the cowl, as soon as I hit it with the wirebrush on the hand held grinder it looked like the night sky...
  14. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    good work. I can relate to working outside. we do what we got to do.
  15. Earl Branham
    Lugoff, SC
    I had to build my car living in an apartment complex. Made a few enemies on that one, but it can be done. Just never give up!
