Yesterday I picked up a set of uni lug aluminum slot rims. 2 of them are 14x7 and the other 2 are 14x8. So my question is what size tire should I run on these. I would like the rear of my Maverick to set higher then stock, also how do I mount the uni lugs. I put the rear on to check the bolt pattern and noticed the diameter of the axle was smaller then the diameter of the mounting hole in the rim. Is this how they should be?
