Ranger master cylinder
Discussion in 'Other Automotive Tech & Talk' started by ford84stepside, Apr 28, 2013.
  1. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Anybody know off hand if the line threads on a 99 Ford Ranger master cylinder would be standard or metric? Got one I was thinking about using on the Lincoln if it has standard threads.....
  2. Rayell
    Rayell Member
    Lizella, GA
    1975 Maverick, 1963 Falcon Ranchero, 1993 Ford Ranger, 2000 Ford Taurus
    They are metric on my 93 Ranger; If that is any indication.
  3. ford84stepside
    Berry Alabama
    That's what I was afraid of. I guess there might be some metric to standard adapter fittings out there. I could just make new lines with the metric fittings on one end and standard on the other, but I don't have the double flaring tool, and have never used one of them. Just trying to save a buck here and there and use what I've got in the stash....
  4. rthomas771
    I got a early '91 Ranger MC on my Falcon and it's SAE threads and 15/16" bore. The later '91-up are metric and 25mm (1.062") bore. I did have a 91 Mustang MC with 25mm bore with the plumbing on the engine side of the MC. The pedal feel was close to the same as with a 15/16" MC
  5. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    I was in a similar situation when I needed to change tube nuts on pre-bent brake lines. I took them to a hydraulic shop and they did the flares with their pro dies. Beautiful job and they charged me $5 or $10 labor. I don't like adapters. :(
