does anyone know how much a console is worth. also i read before in the forums a rare find. is a boomarang what is it and were does it fit on the maverick
The factory Maverick consolettes generally go for between $75.00 and $150.00, depending on condition and whether it has a clock, especially a clock that works. Sometimes you'll see them go a little cheaper if there are broken mounting screw holes, the block-off plate or clock is missing, if they have no keys for the door, or other problems. NOS clocks can get really pricey. Obviously, if you'd be lucky enough to run across a consolette at a junkyard or swap meet, you might do better.
