Rear disk brakes on 71 Maverick
Discussion in 'Technical' started by dtlcast, Dec 27, 2009.
  1. dtlcast
    dtlcast Member
    HOUSTON
    Has anyone converted to rear disk brakes? If so, what was used for this setup?
  2. mavgrab302
    search the tech articles. there is a complete write up on using explorer rear disks brakes.
  3. car-nut
    car-nut Glenn
    conn.
    There are also many other "aftermarket" kits available as well.
    I am going to use this kit here: http://www.vintagevenom.com/mustang-cobra-rear-disc-brake-conversion
    $189.00
    $9.95 S&H (US)
    $198.95 Total
    they also have the kit with everything included if you don't want to go find your own parts. :
    Rear brake only conversion with Red calipers, stock replacement rotors and hoses
    $556.00
    $45.00 S&H (total-two 35lb boxes)
  4. rthomas771
  5. car-nut
    car-nut Glenn
    conn.
    I am not completely sure. I do know it uses the e brake in the calipers.
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Here is another place to look for options. They like to use common off the shelf items for their conversions and they are the ones I plan to use when the time comes.
    http://www.scarebird.com/index.php
  7. rthomas771
    If their rear disc kit is like their front disc kit I wouldn't touch it with a 10 foot pole
  8. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    WOW that scarebird kit is scarey:16suspect the brackets look real thin to me
    i dont think i will trust my car and life on those J.M.O.
    im running the vintage venom kit(y)
    brad:)
  9. Boosha
    Boosha Built to run hard
    Buckeye State
    69.5 Maverick,1964.5 Mustang,1966 T-Bird
    go here.http://mmb.maverick.to/showthread.php?t=62914 Grab a cup of coffee,kick back and enjoy an excellent thread.They are cheap,plentiful,replacement parts aval.at any parts store,and very easy to do.IMO just as durable as any aftermarket kit.I've personally done the swap,and it works excellent!(y)
  10. 71gold
    a Guy gave me a complete 8.8 that the rear gear was busted in...it had all the parts to do a swap...:yup:
    deals like that is why i didn't buy...aftermarket brackets...($200) and then have to buy all the other parts to make them work...:Handshake
  11. Dave B
  12. 71gold
    $250 shipped for brackets and...
    Parts required for this kit (installer supplied)
    Drum brake hub from 65-73 Mustang or mid size Ford
    Wheel bearings and seals for Mustang II
    Cobra caliper
    Cobra rotor
    Brake hose
    [SIZE=-1]kinda sucks also...:yup:[/SIZE]
  13. Dave B
    It's only $170 + shipping for the rears.
