rear spoiler and tips ???
Discussion in 'General Maverick/Comet' started by 71gold, Oct 11, 2004.
  1. 71gold
    would someone remind me where to find the "repo" fiberglass spoiler and quarter ext. i tried a search with no luck...frank...
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
  3. 71gold
    thanks dan,
    that was what i was looking for (y) ...sure was a quick reply and you are up mighty early.
    the new mav. sure looks great. looking foward to seeing it in person..frank...
  4. dmhines
    Cumming, GA
    Your welcome .... I was just looking at the link last night so I had it bookmarked. I'm wondering if they still make the version for 74-77 cars with the longer 1/4 extensions so you can add the spoiler and leave the big bumpers on. I'm always up this early for work.
  5. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Was the factory spoiler made out of steel? and how does the spoiler go on?
  6. 71gold
    the factory spoiler is fiberglass. there are four studs that go through the trunk lip. craig, has a mock up of where the holes go. hope this helps...frank...
  7. Maverick73
    Lakeland, FL
    So you have to drill holes in the trunk lid to install it?
  8. dmhines
    Cumming, GA
    Yes ... four approximately 1-inch diameter holes need to be drilled on the edge of your decklid. I'm curious if non-Grabber hoods have the access holes necessary on the backside of the hood to screw on the nuts or if they have to be drilled out as well. Have to check when I get home ...
  9. mavman427
    mavman427 has entered the building.
    SLOtown, CA
    1971 Mav with all the trimmings....302 Auto, Custom buckets, Power Brakes, A/C, PS, Grabber hood, spoiler, and mirrors.
    I believe all trunk lids are the same, grabber or non grabber. My car is not a grabber, and I installed the spoiler no problem, access holes were right where they need to be. When you do this type of thing, just make very careful measurements. Measure twice, cut once they say. I've learned this the hard way a couple of times :).
  10. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    The trunk lids are all the same, just need to drill the holes...
  11. scooper77515
    Just stay away from that Canadian Company that sells fiberglass Mav parts. They ripped me off by just not sending what I ordered...the check cleared, though. They said "we are out of stock of that item, so the next time you order from us (FAT FARKING CHANCE) we will credit what you spent last time toward that order." My thoughts are "yeah, I am out $XX, so I will just send them another $XXX and HOPE that other part is in stock". Stick with companies that other Mavers have had success with.
  12. MapleMav
    MapleMav Member
    Moose Jaw, SK Canada
    '72 Sprint
    Scooper - out of curiosity, do you remember the name of the company?
