Rearend swap question
Discussion in 'Technical' started by MapleMav, Jun 26, 2006.
  1. MapleMav
    MapleMav Member
    Moose Jaw, SK Canada
    '72 Sprint
    May be a silly question but I haven't seen it answered here before. Doing the rearend swap on the 4-door and have everything removed except the emergency brake cables. There's a clip on the back side of where the cable enters the backing plate(see circled area in pic), with a number of small claws holding it in, but it doesn't seem to want to budge very easily (difficult to compress all the claws inward at the same time, they keep popping back out). Is this where I want to disconnect the cables, or is there somewhere else they can be removed that's going to cause me less grief?
  2. Jamie Miles
    Alto, GA
    I've had a few
    That's where I dissconnected mine when I swapped the rear in my '72. Was a PITA.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    You will have to depress them all to remove the cable. You can use a small hose clamp to compress them for removal. Or you can compress a few and pull the cable to the side this will hold the against the backing plate. Slowly work your way around until the cable comes out.
  4. mean_maverick
    With The Last One I Swapped, I Cleared One Of The 'pins' At A Time Then Moved To The Next One But Being Careful Not To Let The Previous One Release. Like Jamie Said, P.i.t.a.
  5. 1972Grabber
    1972Grabber Always Broke
    SAN ANTONIO, TEXAS
    1972 Maverick Grabber
    This is the best way to do it, hands down.
    Just make sure that when you do it this way that you do not put the hose clamp so far down that it contacts the backing plate. You will not get it out if you let it touch because now the clamp will be holding it there instead.
    Also, make darn sure you use a GOOD hose clamp to do this. Made in China = crappy clamp. Find a different one that is NOT one of the cheapies. (y)
  6. MapleMav
    MapleMav Member
    '72 Sprint
    Man, you guys rock! The hose clamp trick worked like a charm. Of course I broke the first clamp I tried 'cause I overtightened it, so I had to "borrow" one from my fuel line, but that's my bad. Guess I better remember to put it back on the fuel line before I start the engine again...
    Anyhow, thanks a bunch! :urock:
  7. Mavaholic
    I use a cutting torch when possible.
  8. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    The hose clamp thing works very good. One other way is to use a 9/16 deep well 6 pt socket. Just slip it over the cable end, align 3 of the flat spots on the socket, push the socket down on the tangs and it will come right out.
  9. inline6
    inline6 Member
    this is the easiest way i found.works great everytime.
