rebuilding 302
Discussion in 'Technical' started by a-train, Jan 29, 2009.
  1. a-train
    a-train New Member
    red deer
    1974 comet gt
    hi im rebuilding my 302, i didnt want to spend to much cause im planning on buying a crate engine later, im just planning on using my comet for my upcoming wedding, so im just looking some info on a better cam kit since im in their and it should give some life to my engin. Also need a engine rebuild kit, 1 intake valve, if anyone knows a good place to pick these things up that would be great!
  2. mean_maverick
  3. timsrick
    timsrick Member
    woodville,ont.canada
    1977 maverick,77 comet
    pretty much any auto supply store,napa,carquest etc..there not expensive.
  4. Bryant
    replacing the valve springs on an old motor will wake it up considerably. if you change the cam defintly get the matching valve sprigs for it.
  5. 71gold
    reman. long block ...from Advance, Auto Zone or O'Riley's would be your cheapest, being you are going to replace it later...:yup:
    ...JMO...
  6. a-train
    a-train New Member
    red deer
    1974 comet gt
    gettin a kit
    this is what come in the kit.
    Stock style Federal Mogul/Sealed Power Camshaft,
    Stock style Federal Mogul/Sealed Power Lifters,
    Stock style Melling Timing Set,
    Stock style Federal Mogul/Sealed PowerPistons,
    Stock style Federal Mogul/Sealed Power Piston Rings,
    Stock style Federal Mogul/Sealed Power Rod Bearings,
    Stock style Federal Mogul/Sealed Power Main Bearing,
    Stock style Durabond Cam Bearings,
    Stock style Melling Oil Pump,
    Stock style Pioneer Frost Plugs,
    Stock style Victor Reinz Gasket Set,
    what upgrade cam should i get with a stock torque converter.
    -Crane 130032 260/260 adv dur .456 .456 lift
    -Crane 130042 266/266 adv dur .469 .469 lift
    -Crane 130052 272/272 adv dur .484 .484 lift
    -Crane 130092 278/278 adv dur .498 .498.
  7. Mavman72
    Those look like chevy cam grinds.Get an asymmetrical cam with more exhaust lift than intake.Stock ford heads stink on the exhaust side.Dont go over 225/230 duration at .050 with stock converter/gears.Also get a cam with a 112/114 LSA(lobe separation angle) you wont like a tighter one in a stock application.Are those pistons flat top or dished??? if they are dished...get flat tops...worth a few points in the compression department(you will need all the help you can get here)in short...I would just get a re-man short block as suggested by Frank.What you will spend in machine work alone will make the re-man cheaper.Good luck whichever way you go.
