Refrigeration Disconnect Info Needed
Discussion in 'Technical' started by kukm66, Nov 28, 2007.
  1. kukm66
    kukm66 Member
    Phoenix
    1972 Grabber, 1964 Falcon Futura Convertible, 1964 Ranchero
    I am going to disconnect the refrigeration unit on my Maverick for now so I can deal with other issues. Since this system is supposed to be pressurized, what steps do I neet to follow before disconnecting the hoses?
  2. Slantsickness
    Slantsickness Member
    Tucson, Az
    1975 2 Dr.
    Legaly you need to have the system evacuated. People have been known the simply disconect the hoses and let the system discharge into the atmosphere (with it off, pressures usually under 100 psi), but the EPA says thats enviromentaly irresponsible.
  3. Mavaholic
    Plus there is a 5 figure fine if you get caught.
  4. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    Crack the connection with a wrench and let it bleed out. Don't breath it.
  5. newtoford
    newtoford Member
    New Castle Delaware
    i just hold the valve stem looking things open with a screwdriver.
    or you could do it the right way and have it professionally drained or get the supplies yourself and drain it into a canister or whatever they use.
  6. blugene
    Crack squeek squeek sssSSSSSSSS! ;) j/k!
    See if any local shops want some free on...
