replacing drivers door window glass QUESTION
Discussion in 'Technical' started by 510madmav, May 11, 2009.
  1. 510madmav
    510madmav Member
    San Francisco bay area
    1973 Maverick
    i broke my drivers side door glass. but i bought a 74' comet glass at a wrecking yard. the rails look different, will it fit? is it the same as the mavericks? please tell me it will work :cool:
  2. 71gold
    there are 2 different hole spacings....just make sure they match...
    Jeff and i got to looking at different doors in a junkyard once and found about 5 differences in them...:rolleyes:
    ...:Handshake...
  3. 510madmav
    510madmav Member
    1973 Maverick
    yeah, they are different. i'm going to see if i can get a glass guy to cut me a new hole. otherwise the glass is the same shape.. does any company make maverick glass?
  4. rayzorsharp
    Might be easier to get the rail (regulator) out of the junkyard door.
  5. 510madmav
    510madmav Member
    1973 Maverick
    that was an option too, but i'd have to drill the rivets and all that crap; may have to though if the hole cannot be cut.
  6. rayzorsharp
    No rivets...it's all bolt in
  7. 510madmav
    510madmav Member
    1973 Maverick
    i'm not near my car right now.. than what do those 4 or 5 rivets hold in?
  8. rayzorsharp
    You're right, I forgot that some of them are riveted in. All of mine are bolted in. I just went out and looked at some of my spare doors and did find one with rivets. They are fairly easy to drill out at least. Knock out the center with a punch and drill with a 1/4" bit. They are aluminum so they drill pretty easy.
  9. rthomas771
    I'm thinking the '73's had rivets...or maybe some different color Mavericks had rivets.
  10. 510madmav
    510madmav Member
    1973 Maverick
    is there anyplace to purchase maverick glass?
  11. rayzorsharp
    Very unlikely. Your only hope would be to get your local glass shop to check their suppliers. The last time I bought a new glass was about 7 years ago but I did get one. Can't hurt to try them.
  12. yellow75
    Tillamook Oregon
    One more thing you need to look at when replacing the glass. A/c cars had tinted glass and non a/c glass was clear. As far as I know you cant buy new replacement glass for door windows. Measure the hole spacing in the channel that holds the glass in your car, I have some side windows of tinted and clear if they are the same.
  13. 510madmav
    510madmav Member
    1973 Maverick
    i have the glass already but, the holes just dont match up...i know little about glass; so is adding the hole possible? my dad knows a glass guy that will probably do it free if it can be done.
  14. rayzorsharp
    I've never seen anyone try to drill tempered glass. It doesn't take much to shatter it. I'd have to leave that question to the glass guys.
  15. Jamie Miles
    Alto, GA
    I've had a few
    Tinted glass was an option on all of them, not just ones with A/C. My '72 beater has the tinted glass with no A/C, and the Ford 999 report had it on there as an option.
