Replacing the Oil Pan Gasket
Discussion in 'Technical' started by 71maverick, Oct 25, 2007.
  1. 71maverick
    71maverick Member
    Moline, IL
    I have a 71 Mav, with the 200-I6, automatic trans. I need to replace the oil pan gasket. Can this be done without pulling the engine?
    Thanks in advance
    Glen
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Don't see why not. I have done it on a v8 car and all I had to do was remove the belly bar (not on 6 cylinder cars) and take out the 2 bolts for the idler arm to drop the steering linkage down for clearance.
  3. newtoford
    newtoford Member
    New Castle Delaware
    you wont need to remove but you'll need to take the front sway bar out to get the pan out and probably undo the motor mounts and jack the engine up a little with a floor jack. i think on 170's and 200's the timong cover either needs to come off or be losened
  4. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    I have done this before. Unbolt the engine from the mounts and rise the engine. You need to do this to remove the oil pan. The oil pump blocks the pan from clearing. Don't mess with the linkage.
  5. newtoford
    newtoford Member
    New Castle Delaware
    you didnt need to remove the sway bar? it looks like it would caus alot of interfearence
