Rim Question
Discussion in 'Technical' started by fredee, May 19, 2008.
  1. fredee
    fredee Member
    South MS.
    1971 comet
    Have a couple of 14 x 7 steel wheels where the center of the wheel is riveted (instead of welded) to the outer rimshell. Do these require a tube?
  2. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I run 2 piece rims with no tubes.
  3. Craig Selvey
    No tube required.
  4. LBF
    LBF Member
    Missouri
    Riveted wheels
    Riveted wheels are common on Professional Cars, and they will slowly leak air over time. Check your cold pressure often and they should be fine.
