shifter question
Discussion in 'Technical' started by JHodges, Jul 3, 2009.
  1. JHodges
    JHodges thumper
    Dora Alabama
    I installed a B&M starshifter in my maverick. I have adjusted it many ways and have it where I can shift through all the gears. When I pull it pack to 1st I can shift it 1st 2nd drive with no problems. But when I go drive 2nd 1st I have to pull the trigger to go from 2nd to first. I was wondering if this was just the shifter design or do I have a problem
  2. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    when you installed it did you look at the mechanisem that the trigger rides on and see the shape of the teeth? but it sounds like your shifter is fine, it's designed so you can upshift through the gears and not accidentally downshift when your flooring it...
    Put it this way when your in 2nd and your turning about 5,000 RPM's you'll be able to shift up to 3rd bringing you to about 3,000 RPM's or so which is alot better then accidently shifting down to 1st which would bring you to over 6,000 or 7,000 RPM's which is at or over redline...
  3. Mavman72
    Your shifter is fine.Its supposed to work that way.
  4. nc73Mav
    nc73Mav Member
    Rockwell, NC
    Maverick
    your shifters fine, man. thats how its suppossed to be
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Yes, working as designed.
  6. JHodges
    JHodges thumper
    Dora Alabama
    thanks that's good to know. Me and my dad have fooled with this thing for a couple days
