so whos painted headers?
Discussion in 'Cosmetic' started by newtoford, May 20, 2008.
  1. newtoford
    newtoford Member
    New Castle Delaware
    what did you use and how did it work? i was just going to grab some rattle can stuff from the parts store but if it all flakes off in 10 miles id rather not waste my time. its a little easier to get them painted out of the car anyway. a "steel" color would be my top choice, black would be 2nd
    any suggestions that are somewhat inexpensive?
  2. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
  3. 71gold
    prep...prep...prep...:yup:
    i "glassbeaded" mine...then washed them with soap and water...took a tourch and heated them from the inside (down all the tubes and up the collector). let them cool down so i could touch them and then coated with (rattle can)..."High Temp W/C" paint.. :yup:
    ...:Handshake...
  4. Rando76
    Rando76 Member
    Claremore, OK
    I also prepped mine well and sprayed them with header paint in a can. I've got about 1500 miles on them and they're still black. (y)
  5. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I used hi-temp ceramic aluminum coating-rattle spray on. It burned off quickly. The Eastwood coating, or similar, or ceramic coating process or powdercoat or Jet-Hot will likely be better.
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I had great luck with VHT Flameproof coatings
  7. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Not sure about headers ... but Eastwood coating worked great on my exhaust manifolds ...
  8. blugene
    Wrap em... but it's not inexpensive nor quick. I just like how it isn't as hot by my plug wires and under hood in general.
  9. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Doesn't wrapping them promote rust, since the headers condensate inside the wrap? Don't know if it's true, but I've heard that a lot.
  10. blugene
    It was already rusty lol. It hides any imperfections ;). I would think it's too hot... :huh:
  11. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    if you dont drive it , i would think they could , but if you drive it on a somewhat regular basis, the mositure will just evaporate
  12. blugene
    :hmmm:... Don't you have a jack stand to adjust or something :rofl2:...;)
  13. Mavman72
    VHT high temp header coatings work well(if you follow the instructions) and if you scrape em up you can touch them up easily.The eastwood stuff workes well too.Header wrap workes if you like the mummy look.Just dont wrap em all the way down.moisture collects at the low points on the headers.
  14. newtoford
    newtoford Member
    New Castle Delaware
    some of the header paints ive seen say that you need to heat the car up within a few hours of paiting the headers. i'd rather not have a short time limit like that
  15. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Tony, I painted mine with rattle can hi temp paint that said to heat them up after being painted....it was two months later before I ever fired the motor! I ran it long enough to get them smoking just a bit, then let them cool to the touch, and ran it again. They still look just like they did after I painted them, but I haven't got any road miles on the car yet, just running in the yard...
