Springs!!
Discussion in 'Technical' started by MICHAEL DAVIS, Feb 27, 2014.
  1. MICHAEL DAVIS
    MICHAEL DAVIS Member
    1973 Ford Maverick
    I want to know if a mustang spring compressor will work to remove them from my 73 maverick.? I can rent one from Kragens..
  2. rthomas771
    Never heard of a "Mustang" spring compressor. But if it looks like this, then yes, it will do the job.
    [​IMG] [​IMG]
  3. MICHAEL DAVIS
    1973 Ford Maverick
    Thanks rthomas yeah they have one that is meant for the mustangs but I didn't know if it will work.. Most the time my question are confusing!
  4. 71gold
    was the "mustang" one the same as the one in the pics?
  5. MICHAEL DAVIS
    1973 Ford Maverick
    Yes it was the same, but need a three inch pipe to make it work to remove springs.. Careful how you do this it will bite you!!!
  6. rthomas771
    :hmmm:...I removed about 20-25 springs and only pipe I used was a cheater pipe on the end of my ratchet.
  7. MICHAEL DAVIS
    1973 Ford Maverick
    I didn't use it correctly but it came out ok.
  8. Blue Brick
    Blue Brick Member
    How do you use it?
