Steering Gear Box
Discussion in 'Technical' started by David74maverick, Aug 24, 2007.
  1. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    Ok another issue with my car... I have alot of play in my gearbox (been this way for along time, but I figured I'll get some research done now), so my question(s) would be, does anyone know where I could get a replacement? Does any other car/truck have the same gearbox (bolts right in same connections, etc.), Does anyone know where I can get a complete rebuild kit and how diffecult is it to do... etc Hopefuly something in a budget... just found out I need lower control arms... damn those PST parts (press in bushing no longer pressed in) sorry for changing the subject... Any steering box help or advice would be appreciated. thanks
  2. scooper77515
    Try to adjust the play out first. Center the steering, and tighten the little screw on the top. Just barely tight, though. Maybe 2 fingers on the screwdriver. Too much and it will further wear the box out.
    The box is designed to have play during a turn, and tighten up while driving straight. The gear inside is not evenly sized down the entire length, and has thicker teeth in the middle so the car won't swim as much when driving straight.
  3. David74maverick
    Arizona
    tried that, it's to worn out. One time I tightended it up to eleminate play and later when I went to have it aligned they went ahead and loosened it up and charged me $60 to do it... they said it was to tight. which I agree, it would bind when turning.
  4. Slantsickness
    Slantsickness Member
    Tucson, Az
    1975 2 Dr.
    Where in AZ are you? I know of a few yards here in tucson that have mavericks. Not sure if they have steering boxes, but its worth a look.
  5. David74maverick
    Arizona
    Mesa/Tempe area... I found 3 Mavericks in a yard around here but I did'nt bother to check the gearboxes either... I wasen't looking the it then.
  6. Rando76
    Rando76 Member
    Claremore, OK
    When looking, remember that there is a ratio difference between the manual and power. Also, don't be afraid to rebuild these - they're easy. Most everything can be bought at your local bearing shop. There are several other threads already on this.
  7. David74maverick
    Arizona
    I've searched the threads but I only came up with 4 results and none where very helpful, maybe I searched the wrong words... what about gears? where could I get these if needed?
  8. Rando76
    Rando76 Member
    Claremore, OK
    Here are a few threads on the subject:
    http://mmb.maverick.to/showthread.php?t=15102
    http://mmb.maverick.to/showthread.php?t=16189
    http://mmb.maverick.to/showthread.php?t=20458
    http://mmb.maverick.to/showthread.php?t=26336
    http://mmb.maverick.to/showthread.php?t=26483
    http://mmb.maverick.to/showthread.php?t=28291
    http://mmb.maverick.to/showthread.php?t=32805
    I don't know where you could get the actual gears. Wear can be taken out by adjustment if they are in decent shape. It seems like when there is LOTS of play, that the ball bearing has gone out. There are two bearings styles in these gearboxes - a roller and a ball bearing - in addition to the balls in the gear itself. Be careful when taking it apart not to lose an rollers and use grease to hold them in when putting it back together. Once is completely clean, assembled, and lubed with oil, you'll find that it will be extremely easy to move. I was amazed at what a difference it made - even when the box wasn't in bad shape before I started.
  9. Acornridgeman
    Wisconsin
    If you can't find a used one someplace - there is a company that sells rebuilts. car steering .com
    http://carsteering.com/partsdisplay/1972_Ford/Maverick.html
    Also - try doing more seaches - there is a bunch of info on these boards. Title of threads can be deceiving as to content - so read read read ... (y)
    search try:
    steering gear
    steering gear box
    steering gearbox
  10. 71gold
    David,
    are you sure it is the ...steering box...or is it the p/s?
    ...:bouncy:...
  11. David74maverick
    Arizona
    I eleminated my ps so it's just the gear box, I used the kit which replaces the control valve.
  12. 71gold
    i removed my P/S and used a kit to replace it. only to find out the kit had as much play as the worn out P/S. i got a pitman arm and draglink from a man-u-well donor car... prob. solved....(thanks Mike) :Handshake
    ...:bouncy:...
  13. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    I have a gear box from a '71 Maverick if still interested
  14. David74maverick
    Arizona
    what ratio? hows the condition? any play? how much? thanks
