Strut Rods
Discussion in 'Technical' started by dotfrost, Sep 29, 2011.
  1. dotfrost
    dotfrost Member
    Mesa, Arizona
    I seem to have trouble getting the passenger side rod off. The driver side rod broke and came off easily, but the one that is not broken wont seem to budge. I got the bushings and two underside bolts off... Where do I go from here?
  2. Craig Selvey
    Did you remove the bolts/nuts that hold it to the lower control arm?
  3. dotfrost
    dotfrost Member
    Mesa, Arizona
    yeah... I'm stuck.
  4. bmcdaniel
    The bolts in the lower arm are splined and press into the arm. Sometimes you need a BFH.
  5. dotfrost
    dotfrost Member
    Mesa, Arizona
    Hahaha! Thanks! Lemme see where there is one...
  6. 71gold
    here ya go...
  7. rthomas771
    The bolts are pressed into the strut rod...not the LCA.
  8. bmcdaniel
    Yep, but I thought I recalled that the splines on the bolts were also captured in the LCA?
