Stupid door question...
Discussion in 'Technical' started by maverick656, Nov 20, 2013.
  1. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    I need a striker panel for my 75 4door Maverick, on the drivers door. I know I should just go look, but I'm in college right now, and I won't be able to make it to the junkyard for a week or so. Are there any other vehicles I should look for that have the striker panel that will fit my car?
  2. Craig Selvey
    Are you talking about the striker inside the door jamb? Not on the door....but on the jamb? You can buy them brand new. I have used ones if you want me to mail you one. Email me DIRECTLY (see below) if I can help.
  3. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    Yes, in the jam. Not on the actual door itself. The one I have on there is worn and the door shakes because the striker itself is worn
  4. 71gold
    ...you might want to find out why it wore out.
    hinge pins worn, hinge pin bushings worn, rusted out door jam causing the door to sag, just a few things that will cause that.
  5. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    Well I replaced the mechanism on the door that latches onto it. For a long time it was sticking, causing me to bang the door off the striker. So I'm 99% sure that's why it's worn
  6. Craig Selvey
    I have a used striker if you need it.
  7. mav1970
    Sounds like there is something misaligned between latch and striker :hmmm:
  8. 71gold
    me thinks the same thing. the latch only...latches...the door, it doesn't hit the plate. it just trips the latching mechanism...:tiphat:
