Subframe connectors, am i going overkill on it?
Discussion in 'Technical' started by ESampson, Dec 9, 2012.
  1. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    They're going to be 2" square tube with 1/4" thick wall..is it way overkill or what? i'm not sure how think most use...because this tube is pretty damn heavy and i don't want to weigh my car down this much if it's not needed.
  2. Acornridgeman
    Wisconsin
    Not overkill, but make sure to get it fit high up into the cars floor so it doesn't hang down and scrape going into steep driveways. The best way is to actually have it go up through the floor pans and then weld the pans too onto the connector. Makes it all really strong but it will mess with your carpet for rear seat passengers.
  3. blugene
    Lol.. I don't know for sure but I do know 1/4" 2x2 is thick and heavy. I use it sometimes in my gate business. Seems more like 4 wheel drive materials haha..
    I seem to recall guys using 1x2x14ga.. I would think 11ga or 3/16 is better on the weight than the 1/4 stuff. Sometimes it's not about the thickness but the dimensions.. So 2x2 might be good..
  4. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    carpet will be messed anyways as i have full length mustang pans in now i put in last month, i think i could get them pretty much flush with the pans, they are veryflat compared to the stock pans our cars come with so i may be able to weld them to the floor. i will have to take a look at it when i get back to the shop this week.
  5. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    I used 3/16 2x2 I believe it is plenty stout. I can jack the car up in the middle and there is no bowing or flexing that I can tell.
  6. 71gold
    mine are made from rollbar tubing...bent up on an...exhaust tube bender...:thumbs2:
  7. Joe Dirt
    Yes way overkill 11 gauge is really, factoryis (14 gauge) 1/4 wall is all just excess weight
    What you want is 1x2 11 gauge for extreme apps and 14 for street cars
  8. groberts101
    groberts101 Member
    Minneapolis, MN
    ^^^ that man knows his stuff!
    1/4 inch thick would be great if you're building a monster truck Comet though. And.. how cool would that be?! lol
    PS.. you'll never get proper welds with that stuff to the floorboards either. You'll either burn through the floorpans.. or not get full penetration to the square stock. And it'll likely be both if you do try to use it anyways.
    blugene likes this.
  9. Acornridgeman
    Wisconsin
    I guess a 1/4" would be a bit thick. I just looked up mine (Competition Engineering) and they are 2x2 .083" thick.
  10. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    thanks everyone for the responses..just saved me like 25lbs or more on the weight of my car...gotta get more sq/ tube now.
  11. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    Can you post a picture of this? Thanks! We're going to build some for mine next week.
  12. mav1970
    .125 wall is a pretty common tubing wall thickness and is plenty strong
  13. 71gold
    $75... bent up, installed and out the door...:chirp:
    sitting on 3 pads of my lift...seems to be pretty stout...:bouncy:
  14. Country Mav
    Evans, Louisiana
    Thank you sir! Your car is so clean underneath! Super nice.
  15. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    Here are some pictures of mine on the car.
