Supporting a Maverick
Discussion in 'General Maverick/Comet' started by bhellickson, Oct 29, 2013.
  1. bhellickson
    bhellickson Member
    S. California
    1970 x2 71x2
    This may be an obvious question but one I am not wholly certain of. I plan on placing my 70 on blocks to remove the engine trans and rear suspension. However given the uni-body construction i am concerned as to where to place the blocks to prevent damage. Any thoughts? My initial inspection seemed to favor just ahead of the rear spring attachments and just behind the firewall.
    Thanks for you input..
  2. predfan2001
    My advise would be don't use blocks. I had one collapse once under a car.
    I use jack stands only on flat ground. Front ones under the flat area at the torque boxes. Rear under the rear rails.
  3. rthomas771
    A guy I know got killed last year when his car fell off blocks. He been working on cars for 45-50 years. Be safe and use jackstands
  4. Mavman72
    Use jackstands...Blocks (cinder blocks) are not not meant to hold weight in the standing on end orientation everyone uses em in. Look at how buildings are built with em. Blocks also never carry a full load they are allways staggard to distribute the wieght. But yes...Where you want to use em is fine just use jackstands...Not blocks.
  5. mercgt73
  6. predfan2001
    Nice. My dad has some of those.
  7. Dave B
    I do kinda the same thing, but with 2X4 s, screwed together, and I can add to the height if needed.
  8. predfan2001
    Maverick Jenga
  9. 71gold
    you may want to remove...the engine and transmission... before you block it up...pull them together...:yup:
  10. predfan2001
    Or even raise just the rear while you remove the engine and trans. I just had a hoist and it made it easier. :thumbs2:
  11. olerodder
    olerodder Member
    NorCal
    I use jack stands, but also support the front crossmember with a floor jack as well as support the rearend with one also.............be safe even if it's overkill......................is worth more than your life................IMHO
