timing a 1972 200
Discussion in 'Technical' started by 73curtis, Jan 3, 2015.
  1. 73curtis
    73curtis Member
    ohio
    put in pertronix ignitor,checked timing and the most I can get is 4 degrees, turn it anymore and it hits the dip stick , starts and seems to run just fine,didn't get a chance to drive it yet do you think 4 is fine it says 6 on the valve cover, anyone ever ran into that?
  2. doncomfort
    chillicothe oh
    My 200 was like that. I tried restabbing the distributor but it wouldnt drop in any other way. I ended up moving all the plug wires over one spot and reseting the timing accordingly.
  3. 73curtis
    73curtis Member
    ohio
    did it run better after that, how did it run before you did that
  4. doncomfort
    chillicothe oh
    I was able to set the timing at 10 degrees btdc and had no interference with the dipstick anymore. My 200 amd my 250 like a lot of advance. Spec calls for 6 degrees so I dont think you will like it at 4.
