trans change help
Discussion in 'Technical' started by busyb187, Jan 9, 2011.
  1. busyb187
    busyb187 Member
    california
    1971 ford maverick v8
    hey guys, i need to change my transmission on 71 maverick 302 v8. does the c4 on a 76 torino with 302 engine fit on my 71 maverick?
  2. Streamliner
    Streamliner Member
    Should be exactly the same
  3. baddad457
    Not it will not. It will bolt up to the motor, but the transmission crossmember will need to be changed. Also the output shaft on a C-6 is 31 spline vs 28 for a C-4. A C-6 is also 3-4 " longer than a C-4. The flexplate will also need to be changed to a 164 tooth unit......................all this and not to mention the shifter linkage will likely be different too. The C-6 is a better transmission in my opinion, but it's not a bolt in swap.
  4. don graham
    He's not changing from a c6. It's still a c4. Should be a direct swap.:)
  5. baddad457
    :slap: Brain fart.:rofl2:
  6. PaulS
    From late 72 until 1982 all C4s were the same case.
    Yes it is a direct replacement. Internal differences between the small sixes and the V8s makes a difference but from one 302 to 302 is always OK.
  7. rthomas771
    If one is a column shift and the other a floor shift you will need to remove the pan and valve body to flip the shift lever.
  8. PaulS
    You will need to transfer the shift levers over from one to the other - just flipping the lever 180 degrees won't work well.
  9. busyb187
    busyb187 Member
    california
    thanks alot everybody :beerchug:
  10. baddad457
    Ditto, tried that once and it didn't go well. If he's got an aftermarket cable shifter, it doesn't matter which he uses.
  11. pipman76
    pipman76 Member
    alabama
    1972 mav
    i have a late 70,s torino c-4 in my 70 maverick the differences it had was that tranny was a pan fill instead of the case fill. mine also came behind a 351m so i also changed the bellhousing
