trans wont change
Discussion in 'Technical' started by busyb187, Dec 21, 2010.
  1. busyb187
    busyb187 Member
    california
    1971 ford maverick v8
    hi everyone. i was driving my 71 302 maverick with c4 aotu trans today to the store and it was changing normal. after stopping at a red light, when i took off car wouldnt change from first gear. pulled over and oil level is good. reverse goes in and park as well but wont go past first gear. any ideas of what might be problem or how to fix? thanks
  2. don graham
    First things I would check would be the linkage and the modulator. I'd do the linkage first just cause it's the easiest to see if anything is wrong. if it goes into reverse and park. I'd think linkage is not the problem, but I'd check it anyway then I'd try replacing the modulator. After that I'd be waiting for Paul to show up on this post.:)
  3. Jerryfow2
    Jerryfow2 Member
    Milltown IN
    1972 Grabber/1972 Sprint/1976 Stallion
    I would check the Modulator and or vacuum line going to the modulator.
    Jerry
  4. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    Check your vacuum line. They always come off.
  5. PaulS
    Well, they may not always come off but the modulator is what determines the shift points at anything but full throttle. I would check the vacuum lines at the modulator and the other end at the manifold or distribution block on the firewall.
  6. busyb187
    busyb187 Member
    california
    i changed the modulator today and car now changes from 1st to third but after a get to 30mph. it skips 2nd.
  7. FordsForever
    FordsForever Member
    santa clara, ca
    74 mav
    Did you try adjusting the new modulator? There is a procedure in the manual on how to set it.
    RS
  8. PaulS
    It may be shifting so early you dont feel the 1-2 shift or so late that it is not in third yet. The modulator rod has to be in the modulator and the hole in the back of the valve. Try getting on it hard from a start and see if it shift 1-2-3. If not then you may have the rod out of position.
    DO NOT adjust the modulator - the adjustment is only for fine tuning not big adjustments. If you want firmer and later shifts replace the rod with one that is not over the max length. For push-in modulators that is 1 5/8" and for screw-in modulators and C5s it is 1 3/4".
