Try a different year for gas tank?
Discussion in 'Parts Interchange' started by rsillmon, Feb 6, 2009.
  1. rsillmon
    rsillmon Sneaky Snake
    Caroline,VA
    Maverick
    I know now that you can not buy a new tank for a 69.5 and 70 maverick, because its the drop in type. But what about buying a newer year maverick tank with straps and modify it to work in my 70'? Has any one done this and hard was it? Thanks for any infor(y)
  2. Craig Selvey
    I have seen it done....it was too wide....so it looked like a hack job.
  3. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I think I would get the measurements on the hole and get a fuel cell that was a close fit, and then fill the surrounding area with some sheetmetal. It would work and look fine if it was done right....
  4. 72MAVGRABHER
    Roanoke, Va.
    I'm assuming you are talking about buying the 19 gallon from the 74-up mavs to replace.... some have done this, i agree with craig, they're too big for ME, but I did this instead...
    http://mmb.maverick.to/showthread.php?t=35490
  5. bmcdaniel
    Nice work, but can that Mustang tank be used as a drop-in like the 69.5-70s require? In the past I considered the fuel cell option. In the end I just took the tank out and sloshed around sealer inside. That was about 17 years ago and it's still holding up.
  6. Mavaholic
    MY convertible project is a 70 model (69.5 actually) and I will be putting in a mustang tank. I have measured the mustang tank and it is longer front to back and not as wide side to side. So it will take some fabricating to get it in. However I have a metal brake and I seriously doubt it will take that much fabrication. Hey Barry, why dont you stop by CJ's, pick up a mustang tank, come on down, and we can install it and write a tech article.
  7. mav1970
    I removed my tank well due to the sides all rotting away and am replacing it with a 16 gallon Jaz oval track cell. This also gave me a chance to have a centered tank so dual exhaust being tight on the driver's side will not be an issue anymore. I already posted some other photos in different post here:
    http://mmb.maverick.to/showthread.php?t=49333
  8. ford84stepside
    Berry Alabama
    [​IMG]That's what I was talking about. You could possibly even get one with the filler closer to the rear, and hook it up to the stock location.
