turn signal not working
Discussion in 'Technical' started by Ed's 75mav, Apr 18, 2004.
  1. Ed's 75mav
    Ed's 75mav Member
    Phoenix AZ
    1975 Maverick
    I have a 75 mav, that I am having problems with the turn signals, the right one works fine, the left one does not work at all I have checked the wiring and the fuse, I have also replaced the turn signal cam and the headlight switch, now the odd part is that when I turn on the head lights and turn on the left turn signal its like I had set the 4 ways???:confused: any suggestions....
  2. 71gold
    e75mav, welcome to the board. a lot of us have light probs. on the mav./comets and it turns out to be a bad ground. check them one at a time.
    my left front parking lite and turn lite was messing up. it turned out to need a front wireing harness. (thanks m.a.v.)
    stick with us and we will get it working...frank...:bananaman :bananaman
  3. Ed's 75mav
    Ed's 75mav Member
    Phoenix AZ
    1975 Maverick
    ok I'll go back through the wiring again, but could it be the neutural safty switch? One thing I had left out is that I am missing the right front marker light on the side. Could that be the cause???? I'll let you know what I find out.
  4. its_not_safe
    its_not_safe Member
    Fort Worth, Tx
    1973 2dr Maverick 302c my other car got stolen!!
    ok i am going to use this topic for my problem
    None of my signals work the left or right the parking lights work just not the signals work. I might go out and change the turn signal cam becuse i have gone out and checked all the wiring and i dont know what to do!!
