V8 swap
Discussion in 'General Maverick/Comet' started by DocRoche, Nov 25, 2016.
  1. DocRoche
    DocRoche Member
    1973 Ford Maverick
    I know this has been hit on several times. The archives have some great articles about it. Just curious on what is absolutely necessary for this swap. This is what I know:
    -Motor belly bar
    -Transmission cross member
    -V8 engine (I know, but still thought i'd add it)
    -2 new motor mounts
    -1 transmission mount
    -I'll be using headers, so no need for manifolds.
    -250 or higher c4 transmission
    I've read several different threads and articles. They mention stuff like gas pedal, throttle linkage, coil springs. So I thought i'd ask what was absolutely needed, and what can be used from the original car with the inline 6. Thanks.
  2. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    You can use the Six cylinder springs. You do not have to have the gas pedal. You do need the throttle cable.
    Slayer likes this.
  3. William623
    William623 Member
    Orlando
    Also if you are using headers I hope you have a floor shifter. Might also want a kickdown rod, you don't have to have it but it is nice to have.
  4. 71gold
    motor mount stands (Mav/Comet).
    DocRoche likes this.
  5. mgabski
    mgabski Member
    1973 Maverick
    My car doesn't have a belly bar on it. I'm sure it wouldn't hurt to have but not required
  6. Krazy Comet
    A 250 radiator can be used but the 170/200 rad uses smaller hoses and probably can't handle the extra heat... You'll also need the complete front engine dress of brackets pulleys etc...
  7. 71gold
    maverick oilpan...
  8. Krazy Comet
    A front sump Ford oil pan is basically a front sump pan... Same was used on Fairlane, Falcon, Mustang, Galaxie, etc... Just be sure it IS front sump...
  9. DocRoche
    DocRoche Member
    1973 Ford Maverick
    My 302 is off a 79 Rancharo. Didn't notice the oil pan.
  10. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Don't have either. But making it a floor shift was the plan.
