Valve adjustment
Discussion in 'Technical' started by Bob Wiken, Apr 12, 2009.
  1. Bob Wiken
    Fayetteville, Arkansas
    Help. I can't seem to get my valves adjusted properly. I've done it 3 or 4 times. Everytime I start the car, for a few seconds and check, there are a couple of rocker arm nuts that are loose. i.e. finger adjustable. What am I doing wrong? I've tried 2 or 3 different ways with the same results. I stumped.
  2. Blown 5.0
    MS.
    1974 Maverick
    How much preload are you using? Are the nuts worn out?
  3. Bob Wiken
    I have bolts in my rockers
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    If you have the bolts, you just torque them down tight, there are no other adjustments unless you use shims....
  5. Bryant
    sounds like your adjusting them like studmount rockers and that you are adjusting them while they are on the lobes of the cam. with bolt down rockers you bolt them down to 15 ft/lbs. you check the contact pattern on the valve stem by puting grease on it and turn the motor over 2 full rotations by hand. the rockerarm should stay pretty centered on the valve stem. if you need to adjust it you have to shim under the pedistal (you should have padistals that the rocker arm sits on) or get a longer or shorter push rod.
  6. Blown 5.0
    MS.
    1974 Maverick
    You set the preload just as you would on any other hydraulic lifter, Once the slack is removed from the push rod there should be no more than 60 thousands preload. The best way to check is to put a dial indicator on the push rod side of the rocker, At zero clearance, Zero the dial, the dial should go somewhere around 60 thousands when the bolt Thur the rocker tightens down.( you may have to wait a minute or two for the lifter to bleed off) If you go very much past 60 thousands (I would say + 20) then you will need shims, If you don't go to 60 thousands ( i would at least want 30 +) Then the pedestal will have to be milled down. But keep in mind the push rod length, Especially if you have to mill the pedestal. Usually shims are needed instead of the milling. I use a black magic marker to check the roller tip track on the valve stem. This is assuming you use roller rockers.
  7. Blown 5.0
    MS.
    1974 Maverick
    You did say nuts.
  8. Bob Wiken
    NO, I have bolts. Nuts was an error
  9. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    check your rocker stands for cracks had the same problem on one motor of mine you can get new ones from the dealer if running stock rockers or from summit for your aftermarket rockers
    brad:)
  10. baddad457
    Sounds like he's got pedestal rockers. Torque em down to 25 ft/lbs. No special sequence needed.
  11. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    No special sequence as in, it doesn't matter in what position the lifters are in?
    (I know this is an old thread..)
  12. bmcdaniel
    With pedistals, lifters on the lobe base circle, from zero lash to 25 lb-ft torque should take from 1/4 to 1 full turn of the bolt. Any more or any less turning requires shimming the rails or different length push rods.
  13. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    Sweet! Thanks! That will help double check my pushrod length :tiphat: I already have most of them done. I'll do it on a couple and see how it lays.
    Thanks!
  14. baddad457
    I've never bothered with getting the lifters on the base circle, completely unnecessary step in doing so with pedestal rockers.
  15. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    Woohoo! That's awesome! I did them all with the lifters down and in firing order haha, but it means I definitely didn't mess that part up! :bananaman
