valve comer smoking
Discussion in 'New Members Forum' started by busyb187, Oct 17, 2010.
  1. busyb187
    busyb187 Member
    california
    1971 ford maverick v8
    hi, my 71 maverick is smoking from one on the valve covers. it smokes from inside and the smoke comes out of the breather. its a 302 v8 engine.
  2. maverick75
    Is your PCV in working condition?
  3. busyb187
    busyb187 Member
    california
    to be honest i dont have a pcv valve. i have 2 breathers. do you think i should put a pcv instead of one of the breathers?
  4. maverick75
    Depends on your engine build. If its stock/mild then you should. Your probably getting blow by out of one of the breathers. By using a pcv itll recycle them back into the motor.
  5. busyb187
    busyb187 Member
    california
    ok thanx. i will go get the valve today and give it a couple days to see any changes. thank a mill!!!
  6. busyb187
    busyb187 Member
    california
    thanx a lot. i put pcv valve and smoking from cover has stopped.
