welding leads as battery cables
Discussion in 'Technical' started by JHodges, Feb 20, 2010.
  1. JHodges
    JHodges thumper
    Dora Alabama
    has anyone done it. I am planning on running a trunk mounted battery in the maverick and have a bunch of welding leads. I figure it should work good
  2. mercgt73
    Those are the best battery cables out there! Fine strand copper wire the size of your thumb. (y)
  3. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    YEP YEP YEP ! ! ! Thats what I used,,,, open your wallet :thumbs2:
  4. Thack
    Thack vision advicator
    Moreno Valley Ca
    That's what I used in both cars.
  5. baddad457
    :D careful now here, someone might accuse you of being a Redneck :biglaugh::thumbs2:
  6. PaulS
    As long as the cable is 0 or 00 size it will be fine 1 AWG is on the verge of being too small for the run from the trunk so it causes a voltage drop while cranking.
  7. don graham
    I've got that in my car.:)
  8. bmcdaniel
    My company makes automotive battery cables, 90% of our customers specify welding cable because it's very flexible. As Paul mentioned, use at least 00 from the trunk.
  9. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    i ran them years ago on my 66 impala.
    i picked up some awsome cable off the bay too. high strand cable is pretty easy to get now days.
  10. Bryant
    i rember reading that welding cable is not good to ues for bat cables. now i personaly have used it and had no problems. and i cant rember the reason that was given but i do rember it seemed sound at the time. the way i figure it is coper is coper and how can it it being softer or stiffer mater in this situation. im just puting this out there just incase somebody does have a problem with the cable or even knows what the problem with using it is.
  11. ptpdub
    ptpdub Member
    canada Sk.
    i used to use it to power many amps in some old car audio cars i had. drew far more power than a starter. i used welding cable on all of them and it worked perfect every time. go ahead. it will work great!
  12. blugene
    So are you guys running the cables to the factory solenoid location and to the front of the engine block? Would the torque box on the pass side be a good relocation spot?
  13. baddad457
    I ran mine to the factory solenoid location. But even though I had big enough cables, I had so many problems with the battery being relocated, that I moved it back up front. The problem I had was with hot starts.
  14. PaulS
    Baddad,
    What size cable were you using? If the cable is too small you can easily get hot start problems. (hot copper has more resistance than when it is cool and 1AWG is very prone to that when running the distance from the trunk to the front of the car. Anything smaller would definitely be a problem.
  15. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    1/0 is plenty if the car is wired correctly. 2/0 is overkill.
