What posi and axles is everyone using?
Discussion in 'Technical' started by 75Mav91Stang, Jul 22, 2007.
  1. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    1970 and 1975 Ford Maverick
    I can't seem to find any axles or posi set ups for the 8inch :hmmm:
  2. 390S302
    390S302 Member
    Johnstown Pennsylvania
    1966 cyclone & 1974 comet
    I have the powertrax fully streetable locker it is for the ford 8 and 9 in. open with 28 spline axles.
  3. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    The axles are the same as the one-legger rear-ends.
    I think Auburn Gear makes a Traction-Lok unit for the 8-inch...
  4. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I had a lock-rite locker in the 8 inch with the stock axles before changing to the 9 inch with a spool and 35 spline Moser axles.
  5. scooper77515
    There is plenty out there for the stock axles. I was leaning toward powertrax, but got cheap and went with a mini spool for $40, or maybe $60. I don't recommend that, save up the $350 and put in a "limited slip" locker.
  6. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    Thanks guys :cool:
    How many splines is the stock axle? And is it worth upgrading if I'm just doing a mild build of a 302? Or will the stock axles be fine?
  7. tim keck
    sharps chapel,Tn
    Stock axles work fine,seen several 8"s in 11-12 sec cars with no more than gears/spool.
  8. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    Alright cool :cool: Saves me some money.. So I guess all I need is a limited slip and a set of 4.10s now
  9. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    Actually I was just doing some calculating and it may seem like 4.10s would be too much. I need everyones opinion.. :oops: It would be like a 25in-26in tall tire with a c-4. With 4.10s it would spin at around 3,400rpms, seems a bit much
  10. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I would suggest something in the 3.90 range, it's a good street strip, stoplight to stoplight gear. The 28 spline axles (stock) are the same as the 9 inch 28 spline axles. Fine for a car that is mostly street. Save for some sort of posi or locker and the gears will make the most noticable change. Good luck!
  11. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    ^ Yeah thats the next big thing I'm getting :dance:
    I have 3.73s in my mustang so I wanted something bigger so maybe I'll try 3.93 or something :cool:
  12. maverick1970
    maverick1970 MCG State Rep
    Missouri
    You don't have as many choices with an 8 inch vs 9 inch
    Typical ratios on new gears
    3.00, 3.25, 3.40, 3.55, 3.80, 4.11, 4.62
  13. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    3.80 it is then :oops:
  14. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    If you are using a stock to mild cam, a set of 3.55 gears would be the ideal for the street. If you are going to use an AOD or a 5-speed, you can get away with 3.90 and lower gears. An AOD with a 4.11 gear would have a final drive ratio of around 2.85. That's having your quick performance and gas mileage, too.
  15. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    Its going to be a c-4 for the time being. So.. I'll look around at my options, I guess it'll be between a 3.55 or 3.80
