What's up? 2 Cold cylinders....
Discussion in 'Technical' started by superlead76, Feb 17, 2010.
  1. superlead76
    superlead76 Member
    Tampa, FL
    1972 Maverick Grabber 347!
    Hey guys. So I go the new 308 running in the Mav this weekend but noticed it was a little off. I fired it up this morning and found that with my infared thermometer, that 6 of the cylinders, at the head, were running about 600° while #1 and #4 we running about 230°. I re-checked and adjusted the valves, checked for ignition at the plug and both were good. Any ideas what could be going on here?
    Thanks!
  2. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Were the valves out? Spark plug gap shut? How`d you check spark?
  3. comet416
    comet416 Member
    michigan
    1970 maverick
    do a compression check on those 2 cylinders and compare to the others. make sure your head gasket is sealed on that side maybe your sucking in h20. or pull those 2 plugs and pressurize cooling system see if coolant comes out.
  4. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Double check that you have the wires on in the right firing order. Does this cam use the new or old firing order?
  5. superlead76
    superlead76 Member
    Tampa, FL
    Thanks guys! I'm just gonna gut the ignition system and start new. I should do that anyway for a new build.
  6. 71gold
    :hmmm:...I would have more of a problem with the 600° than the 230°...:yup:
  7. scooper77515
    Mine were running around 400 at the header tubes, then one was 250 and one was 180. I found that 2 of my rockers had worked themselves loose. One was still on but only barely. The other was laying off sideways. Then when checking, I had one more (all on driver side, and all intake valves) was coming loose and only on hand tight.
  8. Bryant
    my first thought is that youve got those two cyliders plug wires mixed up. also check to see if there is a vacuum port on the intake that is not pluged up.
