Wheels+tire sizes ?
Discussion in 'General Maverick/Comet' started by Mavrick newb, Dec 29, 2002.
  1. Mavrick newb
    Mavrick newb 20 Year old Mavrick fan
    Central Point, OR
    1973 Mav 351w 76 Mav 302
    Whats a larger sized wheel and tire that you guys recomend for the rear, preferably that doesnt rub without doing any mods.
  2. squeal1
    squeal1 Out To Have Fun
    Evansville, IN
    72 Maverick Semi Mod, 75 Project
    I am running 15x8's on the back with P235 60's I did have to add a leaf and reshape the springs but If you springs are still strong it may not rub like mine did but it only cost my about $100 to have them do that to the springs.
  3. Mavaholic
    The biggest I have run is 15X8 rims with 255-60's. About 4" of backspacing is the most it will take.
  4. Earl Branham
    Lugoff, SC
    I have 15X7" rims and 235X15" on the rear, 225X15" on the front, and no interference. BTW, standard springs rear, 6cyl springs on the front. Hope this helps.
    Earl
  5. Maverick Man
    California
    anything between 235 and 255 will work.. now that all depends on how bad your leaf springs are. If they are sagging will your have to go with a 235. One of my cars are lowered in the rear and fits a 255-60-15 (26 inch tall tire) or a J/60-15 (27 inch tall tire).
    check the below link out and it will tell you offsets and other sizes I have used.
    http://www.maverickman.com/TireandWheelSizes.html?996690312770
    good luck
  6. BOSSMAVERICK
    BOSSMAVERICK Member
    Dearborn,Mi
    1972 Maverick Grabber
    I have 15x15 rims with 7" back spacing and 33x19.5 tires.
  7. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    I have 15 x 8 Magnums with 255's in the rear. I had to use a small spacer as I was rubbing the leaf and inner wheel well slighty on sharper turns. That will not be a problem with fresh springs.
  8. Mavrick newb
    Central Point, OR
    Thanks for all the input guys. Bossmav what is that on/off switch for next to your right taillight?
  9. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    That's the kill switch so track officials can kill the engine and electrical systems in case of an accident (or if they see stuff dripping under the car during staging...) -- I suspect he's had that car down the drag strip a time or two... :D
