Where is my C4 tranny drain?
Discussion in 'General Maverick/Comet' started by Flamesoldier, Jun 2, 2008.
  1. Flamesoldier
    Flamesoldier Member
    1973 Ford Maverick 302
    I am replacing my radiator and need to drain my c4 tranny. Do I just drain it by losing it from radiator is is there a plug to drain the c4?
  2. 19BlacK77
    19BlacK77 Member
    There is no plug to drain it and you probably wont lose that much trans fluid by unhooking it from the rad. If you want to keep the fluid in for sure though just find some little rubber caps to slip over the ends of the trans lines.
  3. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    you dont need to drain the trans to swap radiators...
    just undo the trans lines going in and out of the radiator, hardly any trans fluid will come out...just dont start it with the lines off:dancing:
  4. 71gold
    to drain the C4 you will have to loosen all the trans. pan bolts...:yup:
    best to replace filter/gasket while you are at it..
    I installeda drain plug in my pan..
    ...Frank...:Handshake
  5. newtoford
    newtoford Member
    New Castle Delaware
    just put an oil drain pan under your rad and undo the lines. like they said, you'll just get a few drops.
  6. allstate81140
    allstate81140 Member
    Visalia, California
    1972 Maverick Sprint
    Hi all. Never did understand why so many auto manufacturers didn't put on oil pan drains. I mean they could have made them to countersink into the pan if it was 'catching on something that they were worried about'.
    It can be a real mess sometimes when there is no drain. Yeah, if I had the pan off, I would also install a drain if I ever did another.
    Engineers. Bah, humbug!
    Jack
  7. Dave B
    I think that usually if your going to change your tranny fluid, you should change the filter also, so you'd have to remove the pan anyways.
  8. don graham
    Yeah, but it's easier and neater to get it off when the pan is already drained.:)
  9. PaulS
    Even with a drain plug in the transmission pan it is a mess after you pull the pan. It slowly leaks from everywhere after the pan is off - and it keeps leaking for days.
  10. don graham
    I have an oil pan, about 3'X4', that I leave under there for any dripping. I learned the hard way.:)
