Which one of these Cragers will work?
Discussion in 'Wheels and Tires' started by 75Mav91Stang, Sep 17, 2008.
  1. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    1970 and 1975 Ford Maverick
    I want to get some 14x8 Cragers to fit my 245 60r14 tires. Which one of these wheels will work for me?
    Normal:
    Rim Size: 14x8
    Bolt Pattern:5x4.5,4.75,5
    Offset MM: -6
    Rear Spac.: 4 1/4
    Or the Reversed offset:
    Rim Size: 14x8
    Bolt Pattern: 5x4.5,4.75,5
    Offset MM: -38
    Rear Spac.: 3
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
  3. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
  4. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I don't think 3" backspacing will work very well with an 8" rim. The tire will likely hit the wheelwell lip.
  5. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    Or I can get a 14x7 inch wheel.
    So basically I just need a wheel thats 14x7 or 8 that will fit my tires without problems. I just need to know the offset and backspacing for it to work.
  6. Craig Selvey
    I have 14 x 7 Reverse on my car. 235/60 Tires
  7. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    Cragars look awesome on Mavericks! :thumbs2:
  8. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    3.5" to 4" backspace works best with 7" rims.
    Some members have reported 4.5" fitting, while others used 4.25" and said it was too tight. Probably slight variances in wheel maker's points of measure, or could also be different materials... As aluminum would have a fatter lip than steel, and they may not be outside measures. Also, factory clearances can vary as much as 3/8".
    Might be all of the above.
    You can be safe with 3.5" to 4".
    If you go with an 8" rim, you need to keep it tight as possible.
    4" at least, but could attempt the 4.25"-4.5".
    Any less backspaces will put the tire out near or past the fender lip.
    It's just my opinion, but even if the tire doesn't hit the fender, it's funny looking if the tires aren't tucked away. You tastes may vary.
  9. Craig Selvey
    YES THEY DO!!!!!!
  10. ratio411
    ratio411 Member
    Pensacola
    So Craig, you like Craigers... I mean Cragars?;)
  11. Matterick
    Lake Stevens WA
    i can't wait to get tires on my cragars. it's killing me to walk by and see them sitting in the garage...
