Why such a difference?
Discussion in 'Technical' started by 71nogo, Nov 12, 2010.
  1. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    In reading my chiltons manual, i have discovered that in 1971 the hp was 210 @ 4600 rpm and in 1974 it shows 140 @ 3800 rpm. whats up with that? this is in reference to a 302 V8 w/out electronic ign.:hmmm:
  2. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Around 72-73 they changed the way they rated HP. Another factor, making engine cleaner with less emissions,,, or so they say,,,
  3. strokermaverick
    strokermaverick Member
    If you notice in your Chilton manual, in the engine specs, the engine also dropped from 9.5to1 to 8.5to1 compression ratio. On an old school engine like that, it is enough for a huge hit in the hp and torque. Also, that was the start of the emissions/smog era.:burnout:
  4. don graham
    They also used to rate engine HP at the flywheel. Now it's at the rear wheels.:)
  5. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    "Gross" vs. "Net" horsepower. They used to dyno the engines with no accessories attached. No water pump pulley, alternator, etc. The Man decided around that time that it was unrealistic, so they made manufacturers switch to a "net" horsepower rating by putting standard accessories on the engine when they ran it on the dyno. This exaggerated the amount of power that actually was lost by the compression drop and other emissions modifications they had to do. The actual difference isn't quite that much.
  6. Shorty
    Shorty Member
    Lafayette, In
    If you can find the engine specifications to compare you'll notice that the engines are the same but, as Drew stated above, the manufacturers had to dyno the engines differently.
    Bruce
  7. rthomas771
    Valve timing was retarded also.
  8. baddad457
    :hmmm: They were ? Compression ratio took a 1.5 point hit from 71 to 72, then as rthomas just pointed out, the valve timing was retarded by 4*. And all this was compounded by the switch in measuring HP
  9. justin has a 74
    kentucky
    I noticed the pistons were different (cant say im 100% sure due to it was a 70 motor i tore down)
    early 70s had a early 90s design with the dish and valve reliefs
    mid and late 70s had the flat top design with valve reliefs
  10. baddad457
    I think you got it a little confused. The 68-71 pistons had a slight dish with 4 reliefs. The 72-76's had a huge deep dish (about .250" deep) then Ford went back to the earlier piston design for (slight dish)77-85, then resumed this again for 87-95.
  11. justin has a 74
    kentucky
    So when did the flat tops come in? Ive had both a 77 and an 80 that i know for a fact 100% were flat tops. And every big bumper 302 maverick i have torn down had flat tops?
    Not that im trying to piss you off... i'm just curious.
  12. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    So... with all that i have read in this thread, im gathering that the 74 motor has just about the same hp as the 71. fair statement?:huh:
  13. rthomas771
    No..see post #8. Lower compression and retarded valve timing took some of the HP out of the '74. Bump the compression back and change the timing gear set and it will be very close. I think the cam grind should be different too but I have no numbers for proof.
  14. baddad457
    You could call the 77=up pistons flat tops, as the dish in the center is only a few thousandths deep. Comp ratio was 9.5 to 1 from 68 to 71 with a 58-60 cc head, then down to 8 to 1 with the deep dish added, then back up to the 8 to 9 range in 77 by going back to flat tops and those huge 70 cc chambered heads til 84. There's probably minor differences in piston tops between the 68-71's and the 77-85 pistons they're not identical, but close.
  15. maverick75
    my 75 Had the ones with the huge dish in the middle..
