Will I need.....
Discussion in 'General Maverick/Comet' started by Country Mav, Mar 21, 2003.
  1. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    Will I need the whole rear axle from the donor car (77 4 door mav) in order to swap to disc brakes on my '72 2 door? Please help, Thanks, Preston
  2. squeal1
    squeal1 Out To Have Fun
    Evansville, IN
    72 Maverick Semi Mod, 75 Project
    Hey Preston I don't think I have ever talked to you but I was on another site and read an article about putting disc brakes on the rear, he used the rear end out of a 1977-1980 Lincoln Versailles. This rear end with some very minor mod will bolt right in a Mav. I don't know how hard they are to find but I am considering do this swap, you get the strength of the 9 inch and disc brakes :D Here is a link to his site check it out he has some pretty interesting stuff on there
    Here is a link to his Tech info.
    MaverickGrabber
  3. 76 Mav
    76 Mav Reformed Camaro junkie
    Cobb County Ga.
    76 Mav , 70 Galaxie ,04 F350,03 Mustang,03 F150
    The easiest swap would be to use a lincoln versallas rear ... Also some granadas and monarchs had 4 wheel discs ... Problem is there hard to find ... Theres a slight difference in width i think the lincoln rear is like an inch wider but its an otherwise direct bolt in swap ...
  4. RabidCustoms
    worked fine for me, bolted in no mods or problems
