window issues...
Discussion in 'Technical' started by VTSquire, Mar 23, 2006.
  1. VTSquire
    VTSquire Member
    in a 71 comet, my passenger window wont roll down properly. It appears (from what I can feel) that a bolt that is supposed to hold the window to the track is missing. Could be a rivet, maybe? Anywho... as it is right now, the piece that holds up the window is popping through the top between the window and the door to hold up the window. When I roll the window down (I presume because the piece is wedged against the rear end of the window) only the front comes down. Is a nut and bolt all I am going to need, or is there something that should be keeping the piece attatched to the window from popping up as well?
  2. 71gold
    sounds like one of the plastic pins is missing..you will have to remove the door panal to check this out...frank...:bouncy:
  3. VTSquire
    VTSquire Member
    The panel is off... my buddy just called me to let me know we have a "bolt in a plastic tube" rig ready to go. I was mostly concerned if there was anything else with the window that I might have to worry about...
  4. 1972Grabber
    1972Grabber Always Broke
    SAN ANTONIO, TEXAS
    1972 Maverick Grabber
    Yeah, like breaking the window maybe? :rolleyes: jUST KIDDING. gOOD LUCK.
  5. VTSquire
    VTSquire Member
    window's fixed... it had popped off of the tracks in the front and was missing the pin in the rear end of the window. done and done. On to the next issue... anybody know where I can get the covering for my panel really cheap?
  6. Mavaholic
    What panel, the door panel? If so, you can easily go buy what ever material you like, and glue it to almost any 1/4 plywood or masonite type material from a Home Depot. Door panels are easy to make.
  7. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    AND IF YOU TAKE YOUR TIME YOU CAN GET REAL CREATIVE!! WHY AM i TALKING SO LOUD, sorry cap lock was pushed down....
  8. VTSquire
    VTSquire Member
    Well you know how it is, fix one thing and you find something else that needs fixing... now that the window is fixed, I find 2 new problems. 1, the panel to go back over it is missing all of the pins to stick it back on (passenger's side) and the drivers side panel apparently got too much exposure to light or something, cause the material covering the wood has shrunk and now come off of the panel itself in the middle of the top side. I'm doing a slow but steady restore so I'm trying to go as original looking as possible. At least, all original for anything you can see.
    http://mmb.maverick.to/attachment.php?attachmentid=5703 <---pics I posted many moons ago.
