Windsor jr heads?
Discussion in 'Technical' started by valleyracer, Sep 15, 2006.
  1. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    Is anyone running these heads and what performance gains over D0OE 351w?
    Richard
  2. valleyracer
    valleyracer Member
    Ottawa Canada
    Gaskets?
    Upon looking for O-Ring gaskets for these heads the only ones I can find are Felpro 1006! Does anyone know of any other manufacturers making these?
    Richard
  3. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Im running windsor jr lites. Their good heads i havent had any problem with them at all and i did use my car as a daily driver for awhile. I did some bowl blending and minor port work before installing them on my 11-1 347. MY car at 3000lbs will go 7.19( eighth mile ) on a regular basis at the local bracket races on 93 octane.
  4. greasemonkey
    Sedalia,MO
    No idea on the gaskets i use regular felpro graphite gaskets.
  5. EFIMAV
    EFIMAV Member
    Davenport Iowa
    http://www.allfordmustangs.com//Detailed/630.shtml
    check the above website. compare the windsor junior to the stock GT40P. They really don't have a good stock D00E comparison but it is not all that great. Notice the P head outflows the junior on the intake side but not on the exhaust side.
  6. valleyracer
    valleyracer Member
    Ottawa Canada
    7.19 ET is impressive on the street, was that with slicks or a street tire?
    My set of heads have been O-Ringed!
  7. valleyracer
    valleyracer Member
    Ottawa Canada
    Did they give proper torque specs? If you mill the ring off the heads what cc will the chamber be? A nice bump in compression!
  8. valleyracer
    valleyracer Member
    Ottawa Canada
    I don't need the o-ring , they came this way and can be milled off because I have no power adder! All good info though...what is your engine combo?
  9. valleyracer
    valleyracer Member
    Ottawa Canada
    Nice!
    I can't wait till spring when my new combo is in...I hope to match your numbers N/A with the jr's on 306 H beams and light wt Kieth Blacks and Cam change!CCA-31-254-4
    Brand:COMP CamsCamshaft, XE294H, Xtreme Energy, Hyd Flat Tappet, 294/306-250/256-.554/.558-110
  10. greasemonkey
    Sedalia,MO
    slicks. It's been 7.70 on a regular street tire.Have you bought the heads yet?
  11. sourbastard
    sourbastard Member
    Australia
    1965 Ford Falcon
    Are you positive the flows measured for that head are correct on that site? I've read that world windsor juniors can flow over 200cfm on the intake out of the box.
  12. greasemonkey
    Sedalia,MO
  13. valleyracer
    valleyracer Member
    Ottawa Canada
    Yes I have them now!
  14. greasemonkey
    Sedalia,MO
    just curious. i was considering upgrading.
  15. valleyracer
    valleyracer Member
    Ottawa Canada
    Isent you a pm!
    Richard
