XXR 4 lug wheels
Discussion in 'Wheels and Tires' started by littlecrow, Jan 10, 2010.
  1. littlecrow
    littlecrow Member
    Caneyville, Kentucky
    1970 Ford Maverick
    Well I found a set of wheels that I would like to get but I'm not sure if they would fit because I'm not sure about the fitment issues with mavericks, anyways the wheels are XXR 501 either in 15x8 with a 15 offset and 3in lip, or 15x7 with a 38 offset and a 2.5in lip, I cant figure out the backspacing but I would like to get a set of these if they fit.
      File size:
      8.7 KB
      23
  2. Bryant
    are those offset numbers in mm?
  3. littlecrow
    littlecrow Member
    1970 Ford Maverick
    Yeah the offset in in mm.
  4. littlecrow
    littlecrow Member
    1970 Ford Maverick
    I belive that the 15x7 with the 38 offset convets to about a 1.5" offset.
  5. Bum's_Steer
    Bum's_Steer Member
    Arkansas
    Can you even get those in the Maverick 4-lug pattern?
    Unless the 4-lug Maverick shares a bolt pattern size with a foreign make, I doubt they'll be available with the bolt pattern you'll need
  6. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I would think you can since certain Datsun and Toyota wheels fit 4-lug Mavericks.
  7. 2mav4u
    Tolleson Az
    i dont know if this hepls but maverick bolt pattern is 4x4.5" and 4x114.3mm.
    my friend has some wheels on his toyota (not same as pictured) but they are 15x7 114.3 bolt pattern with 20mm offset which is less than an inch so i should be good.
    as long as you find some wheels with low or 0 offset you should be fine
  8. littlecrow
    littlecrow Member
    1970 Ford Maverick
    Yeah, those wheels are only avalable in 4 lug in eather a 4x100 or in a 4x4.5 so the later is the same bolt pattern as the Maverick.
