1970 maverick 250 what?
Discussion in 'Transmissions' started by miguel, Jun 6, 2011.
  1. miguel
    miguel Member
    GARDENA ,CALIFORNIA
    1970 maverick
    WELL I GOT A 1970 FORD MAVERICK 250CID WITH THE AUTOMATIC C4 TRANSMISSION,AND I WANTED SOME INFORMATION ON WHICH MANUAL STICK 5 SPEED TRANSMISSION I CAN USE ON MY INLINE 6 .I KNOW I WILL HAVE TO DRILL CUT BUT THATS OKAY.:drive:
  2. PaulS
    You can use any transmission from a FSB car. If it comes in a 302 or 5.0 engine (other than the newest 5.0 that is a mod motor).
    The same bellhousing fits the 250 and the 302. You need a flywheel for the 250 due to the difference in balancing but the same clutches and transmissions will work fine.
  3. miguel
    miguel Member
    GARDENA ,CALIFORNIA
    1970 maverick
    Thanks Paul,one two more questions,which kind of flywheel can I use since ima go for a t5?and what year would the transmission have to be?
  4. PaulS
    Get a standard or after-market flywheel for the 250 for a 10" clutch with 157 tooth ring gear.
  5. miguel
    miguel Member
    GARDENA ,CALIFORNIA
    1970 maverick
    thanks man i appreciate it
