3 & 4 speed Bells....
Discussion in 'Transmissions' started by Jay Johnson, Jul 27, 2015.
  1. Jay Johnson
    Jay Johnson Member
    Hawaii
    Are the 3 and 4 speed bell housing the same? I mean will a 4 speed out of a Ford bolt up to a 3 speed Ford? Is that a silly question or what? Amy help would be great. ...
  2. Krazy Comet
    Three & four speed top loaders use same bells, though the ones before '65 have a narrower pattern.. Most if not all the later trans have eight bolt holes....
  3. Ronald Hopkins
    Ronald Hopkins Member Supporting Member
    Morristown Tennessee
    1972 Comet GT
    Small block bellhousings have a smaller hole for the bearing than big block housings. So if you are using a big block transmission you would have to machine out the housing.
  4. rthomas771
    Shorty likes this.
  5. Ronald Hopkins
    1972 Comet GT
    I have a 67 Mustang A code convertible that came from the factory with a 289 4 barrell, three speed. We installed a big block toploader 4 speed and had to use a die grinder to enlarge the hole in the bell housing. It does have a larger input shaft. which you can use in a small block. They do not like to use a small block transmission in a big block car because of the smaller shaft. I don't know about anyone else but this is what we had to do. This top loader 4 speed came from a 390 mustang.
  6. Jay Johnson
    Jay Johnson Member
    Hawaii
    Thanks for all the input guys!!! I am not sure as to what the 4 speed came out of hopefully i can get some numbers off it soon, i have a small block 302 currently with the factory 3 speed, just trying to think ahead as to how had of a "plug an play" this is going to be if it will work at all.... I think the guy said it came out of a 69 Comet, but i guess the numbers on the trans will tell the real story.....
  7. Jay Johnson
    Jay Johnson Member
    Hawaii
    Ok so my guy called me to day and this is the numbers that he gave me, can any one help????
    T10-B1
    WG DIVISION
    W-1 H233
    what is it? how good is it? how well will it fit behind my current 302/3 speed w/stock rearend..... ratio would be nice......
  8. rthomas771
    That's a Borg-Warner T-10 transmission. It fits the early 5-bolt bell housing. Doesn't fit the 6-bolt bell. Bearing retainer is too big/bell housing hole too small.
    H233 = June 23 1963
  9. Jay Johnson
    Jay Johnson Member
    Hawaii
    Will the bell housing fit my 302 if it is still with the trans? And how good of a trans was this back in its day?
  10. rthomas771
  11. Krazy Comet
    That's going to put it at approx the '63/'64 year model break, probably late '63...
    BUT there has to be a six bolt bell that can be used, four of my friends had T-10 in '65 Comets(3) and a Falcon... Lots of '65 Mustangs had them as well...
    BTW it's important to know length if it's around 27" long it a full size trans from a big block, input shaft is different... Small block intermediate models & Mustang used a 24" trans with slightly longer input shaft(at least so on Toploaders)...
  12. Ronald Hopkins
    1972 Comet GT
    Is the shift pattern different on the small block T10 than it is on the big block T10's.
  13. Krazy Comet
    I don't think so, if it were would be in orientation of shift lever(s)...
  14. rthomas771
    Correction on the date code...A=Jan, B=Feb...ect. H=Aug. - 23=23th day - 3=3rd shift.
    Here is my old T-10 dated F 53 2 which is June (F)- 5th(5), 1963(3) and it was made on 2nd shift(2).
  15. rthomas771
    Here's a bell housing link on what, when and why http://mustangtek.com/Bellhousings/Bellhousings.html
