302 swap
Discussion in 'General Maverick/Comet' started by DocRoche, Sep 30, 2016.
  1. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Found a great price on a 302 I want to replace my 250. Comes with everything and turns freely. Just want to verify it will fit. Came out of a 79 Ranchero. Will it work? What will I need to get? Would be going into a 76 Maverick. Thanks guys.
  2. William623
    Orlando
    1973 ford maverick grabber
    V8 mounts, belly bar, transmission brace, throttle cable and manifolds for the V8. Should work find though. I don't believe that is the 50oz one.
    DocRoche likes this.
  3. DocRoche
    DocRoche Member
    1973 Ford Maverick
    That suff hard to find? I thought about headers instead of manifolds. Mounts, belly bar, throttle. Any advice on where to find it?
  4. William623
    Orlando
    Try posting in the wanted section, but the parts are expensive and sometimes hard to find.
  5. William623
    Orlando
    It will probably run you about 300 for everything.
  6. 71gold
    what condition is your radiator in?
    do you have A/C, power brakes/steering?
  7. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Yes on power steering and brakes. No on A/C. Radiator is good.
  8. dyent
    dyent Member
    vancouver bc
  9. DocRoche
    DocRoche Member
    1973 Ford Maverick
    I'll do that, thanks guys.
  10. Krazy Comet
    Correct, no 50 oz engines till '82...
  11. 71gold
    are you going to rebuild this 302?
  12. DocRoche
    DocRoche Member
    1973 Ford Maverick
    I am. Never done that before but that's the plan.
  13. 71gold
    starting rebuilt, I would start with a 5.0 roller motor...JMO
  14. DocRoche
    DocRoche Member
    1973 Ford Maverick
    5.0 roller? Sorry, I'm not well versed in engine swaps.
  15. dyent
    dyent Member
    vancouver bc
    I would just go and rebuild the 302 you just got and search for V8 frame brackets, belly bar etc..........have you heard back from crazyeye73 yet?
    David
